limited setting display
Mar 2nd, 2009
Hi All,
I am using CUCM 7.0. in the IP phone, I only can see limited network configuration setting, for example I can't see DNS setting. how can I see all network setting on the phone?
I've already check enable setting on the phone in CUCM.
any suggestion would be very appreciated.
Alex
mightyking Mon, 03/02/2009 - 12:43
Enter the IP Address of the phone in to a brwoser then click enter. You will see all you need regarding network configuration for the phone.
MK
alex goshtaei Mon, 03/02/2009 - 12:45
thanks for the quick respond, is there any way to see all the config on the phone?
thanks
Alex
mightyking Mon, 03/02/2009 - 12:53
You can press the setting button which can be found on the right side below the question mark button on the phone. Then select option number 2 which is "Network Configuration".
MK
