gb-fairchild Mon, 03/02/2009 - 11:51
Teresa,
I looked at that documentation. Unless I am missing something it tells how to customize a pre-defined alert or an existing custom alert but not how to create a new custom alert. In my custom tab in Alert Central I have 3 custom alerts but it won't let me add any new ones.
Frustrating .....
testeven Mon, 03/02/2009 - 13:38
  • Cisco Employee,
Custom alerts need to be configured using the performance counters. Unfortunately the documentation does not provide too many details on how this works.
I just checked in my lab and the procedure is the following:
1. Go to System--> Performance--> Open Performance Monitoring
2. Find the device type you want to configure the alert to and expand it. You'll need to select a single counter instance to show in the right pane.
3. Right click on it and select "counter monitoring"
4. Right click on the chart and select "Set Alert/Properties"
5. Select the "Enable Alert" checkbox and configure the parameters needed.
6. You will be able to view the alert on the Alert's Custom tab.
Hope this clarifies a bit your question! If it's helpful, please rate :)
Tere.
jtong2003 Tue, 10/27/2015 - 12:55
I can't even get past step one.  It's grayed out.
I am in same boat.  Before, I don't know how I did it, but I was able to add all kinds of tabs.  Now no tabs.
NEVER mind, i had to go to Edit,New Category and it will create a new tab for you.  Not sure why I didn't see that before.
