GRE tunnel and HSRP
yuhuiyao
All,
Does Cisco support the GRE tunnel source to be an HSRP VIP?
Laurent Aubert
I already used this trick to terminate a GRE tunnel on a VIP and it worked. Only your active HSRP router will process the GRE packet. The point is your convergence time will be higher than having two GRE tunnels.
Laurent.
Laurent Aubert
Laurent.
how is this done?
can you post the problem and ways for doing this?
masood
