ACS 5.0 - Problems listing groups from AD to select
Mar 2nd, 2009
I'm trying to configure the user identity stores of ACS 5.0.
I'm using External Identity Stores --> Active directory.
After I configure it it shows as connected and when I click on directory groups all the groups are listed.
My problem is when I try to filter it down. Even if I put a name of a group that is being showed in the first page nothing comes up.
Even if I look for the string "*a*" nothing comes up.
And if I try to see groups from other domains, in the same florest the one I'm joined, nothing comes up too.
Anyway to solve that?
