how can I upload a wildcard certificate to unity connection
Mar 2nd, 2009
  • Bronze, 100 points or more
I have a wildcard certificate that I would like to upload to Unity Connection, but I haven't been able to do so. I would like to use the cert when accessing CPCA so I don't get the certificate warning that displays when using the self-signed certificate. The documentation I have found for certificate management is very vague. My certificate file is in the .pfx format with the private key. Thank you for any assistance.
Mark
jbayuka Fri, 03/06/2009 - 05:55
Most servers use plaintext certificate files. Use the OpenSSL utility to extract the private key from the .pfx file.
MARK BAKER Mon, 11/16/2009 - 10:45
Thanks for your response. I did use OpenSSL to get the certificate in the right format, but when I try to upload it, it says the name does not match the certificate. unitycnx01.sample.com does not match *.sample.com.
Any help is greatly appreciated.
Mark
Jonathan Schulenberg Mon, 11/16/2009 - 16:15
  • Cisco Designated VIP,
    2017 IP Telephony
Hey Mark-
I haven't tried this; however, one thing that people tend to get turned around on with this process is that you need to upload the root CA certificate that signed yours into tomcat-trust first. You then need to reference that in your tomcat cert. Just in case you missed that step...
MARK BAKER Mon, 11/16/2009 - 20:11
Thanks for the reply.
I do have the root installed as tomcat-trust. Before I had figured that out, I would get a different error. After uploading the root, I get the name mismatch error with the wildcard cert.
HTLou from Cisco has informed in a different thread that wildcard certs are not supported. I am going to submit a feature request for all the UC servers to support wildcard certs.
Mark
