03-02-2009 12:16 PM - edited 03-15-2019 04:33 PM
Is there any type of Best Practice for which Distribution Algorithm to use for VM ports? Thanks!
03-02-2009 12:18 PM
vm ports starting any TSP version 8.X and higher are used this way:
1, 2, 3, etc for incoming and N, N-1, N-2, etc for outgoing so match the algorithm
java
if this helps, please rate
03-02-2009 12:23 PM
Is there any document stating the best practice?
03-02-2009 12:33 PM
i don't think i can call that a best practice, that's they way TSP works and you simply cannot change it
simply look at the integration guides for your applicable versions, they're available at CCO, look for them
java
03-02-2009 12:37 PM
What about in the Line Group configuration that the VM ports are in?
03-02-2009 12:43 PM
"simply look at the integration guides for your applicable versions, they're available at CCO, look for them "
To Add Voice Mail Ports to Line Groups
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/401/integration/guide/c51acu4x.html
a little proactivity please
java
03-02-2009 12:48 PM
I was in a pinch for a quick answer, that's why I turned to the forums. And you got me the answer. Thanks for that.
But, I wasn't looking to be lectured on being proactive.
03-02-2009 04:18 PM
Hey Guys,
Just thought that I would throw this in for anyone building Unity Connection 7.x
I thought the variance here was rather interesting;
(Without a Cisco Unity Connection cluster) Click Longest Idle Time.
(With a Cisco Unity Connection cluster configured) Click Top Down.
Hope this helps!
Rob
