Custom URL Categories
Mar 2nd, 2009
I run a url whitelist and blacklist on my S650 and I have noticed some strange behavior.
If I put "somesite.com" in my blacklist it will block the base url "somesite.com". It will not, however, block "www.somesite.com". If I put ".somesite.com" it will block "www.somesite.com" but will not block "somesite.com". Is this intended? Do I have to put "somesite.com, .somesite.com" for every url?
jowolfer Wed, 03/18/2009 - 16:30
RBC,
This is the intended behavior. It's the way that the simple match works. You can use regex matching to only specify the domain, but regex uses 10+ times the amount of cpu for matching.
I recommend never using regex unless you need to match a path.
RBC____CS Wed, 03/18/2009 - 18:44
Josh-
Thanks for the confirmation. It is what I assumed but I wanted to confirm.
