no flow in any port except vlan interface
There are 2 vlans in my switch, the input rate of vlan1 is 13Mb/sec and the output rate of vlan10 is 12Mb/sec. There is no flow in any other port both input and output.
The servers whitch connected to the switch run well. Why would be this ?
There are 2 ports in vlan10 ,one is down and the other is connected to F/W. The remainder ports are in vlan1.
mbroberson1 Mon, 03/02/2009 - 18:14
Hi Yibo,
Have you checked duplex/speed settings of both the switch and the servers? Are you getting errors on any of the interfaces where the servers connect? Start looking at layer 1 then move up. If all else fails sniff it.
-Brandon
