ANI based call routing
Mar 2nd, 2009
We have unique requirement like this.
Phone A Phone B---CM6--3845GW---PSTN-- Phone 1 Phone 2
calls from phone 1 should go to the Phone A, Phone 2 should go to the phone B. (Based on ANI)
Is this possible?
Thnks,
Nicholas Matthews Mon, 03/02/2009 - 19:20
  • Red, 2250 points or more
If you're using H323 or SIP on your GW then you can do this.
You need to make sure you're not using an 'incoming called-number' command on any of your pots dial peers, and do something like this:
dial-peer voice 1 pots
direct-inward-dial
translation-profile incoming 1
answer-address 5551234
port 0/0/0:23
dial-peer voice 2 pots
direct-inward-dial
translation-profile incoming 2
answer-address 6661234
port 0/0/0:23
Then in your translation profile you would have two different called numbers.
voice translation-profile 1
translate called 1
voice translation-rule 1
rule 1 /.*/ /1234/
voice translation-profile 2
translate called 2
voice translation-rule 2
rule 1 /.*/ /5555/
That was the ANI in dial peer 1 will call the number in rule 1, and so on.
-nick
pgamage Tue, 03/03/2009 - 21:15
HI, I am sorry i have forgotten to mention important thing here. This is a CM + CRS installation. so need to do with scripts. any way I would try your method and It will be helpful.
