How to disable this Alarms?
Mar 2nd, 2009
My two WAE have following alarms and donnot know how to clear it.
A. core_dump sysmon core
B. eth_bypass sysmon/eth2 InlinePort 1/1/wan
eth_bypass sysmon/eth3 InlinePort 1/1/lan
eth_bypass sysmon/eth4 InlinePort 1/0/wan
eth_bypass sysmon/eth5 InlinePort 1/0/lan
WAE - A : A Inline mode WAE.
I have delfile /crash/* and reload WAE many times , but alarms still show on Central Manager.
WAE - B : A Wccp mode WAE , and inline card donnot use for half week age,central manager show this alarm,I know inline card 's four port is bypass.because is use wccp.How to disable this alarms.
dstolt Wed, 03/04/2009 - 20:29
Hi Ivan,
See if this helps:
A: Is there anything in the following directories?
If so, you will continue to get the Alarm until it's removed.
B: Are you using WAAS 4.0.19? If so, your inline alarm might be CSCsl62873, which is fixed in 4.0.21 or 4.1.1 or remove the card if it's not being used.
Hope that helps,
