Router on a stick IPSec with external DSL
Mar 2nd, 2009
I need to connect remote site with 2 local LANs to our hub site. Internet is Telmex with 2wire 2701. My solution was router on a stick with 3 trunked VLANs to a switch. 2 local LANs and 1 VLAN that I connect to the DSL modem. Try as I might, no joy on getting ISAKMP to make an offer to hub. Anyone see the errors of my ways :< ! Here is the info for remote:
crypto isakmp policy 1
encr 3des
hash md5
authentication pre-share
crypto isakmp key xxxxxx address 65.xxx.yyy.aaa (my hub)
crypto ipsec transform-set 3desmd5_xform1 esp-3des esp-md5-hmac
crypto map curta_1 1 ipsec-isakmp
description HQ VPN Router to remote VPN
set peer 65.xxx.yyy.aaa
set transform-set 3desmd5_xform1
match address 100
! Local Lan #1
interface FastEthernet0/0.128
encapsulation dot1Q 128 native
ip address 10.30.128.1 255.255.255.0
! Local Lan #2
interface FastEthernet0/0.130
encapsulation dot1Q 130
ip address 10.30.130.1 255.255.255.0
! Segment facing DSL inside
interface FastEthernet0/0.1000
encapsulation dot1Q 1000
ip address 201.122.21.143 255.255.255.224 ******
crypto map curta_1
access-list 100 remark Set interesting traffic for crypto map to traverse VPN
access-list 100 permit ip 10.30.128.0 0.0.7.255 10.15.0.0 0.0.255.255 (hub site)
access-list 100 permit ip 10.30.128.0 0.0.7.255 192.168.125.0 0.0.0.255 (hub site)
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0.1000
ip route 10.15.0.0 255.255.0.0 FastEthernet0/0.1000
ip route 192.168.125.0 255.255.255.0 FastEthernet0/0.1000
****** ISP gave 1 static IP this example shows this, this is a point of brain damage as ISP can not give clear examples using this setup, but claims it will work :(.
