Need help with an object-group on PIX 506
I need to group the following ports for a VoIP device.
514 UDP
1194 UDP
3480 UDP
49000-50000 UDP
443 TCP
I obviously don't want to make 1000+ entries in the PIX config, and I'm a tad confused on the object-group and then how to apply it.
Single IP, translated from the interface to 192.168.1.5. What commands will I need? Thanks so much for any help.
vikram_anumukonda Tue, 03/03/2009 - 04:20
  • Bronze, 100 points or more
object-group service VOIP_TCP tcp
port-object eq 443
object-gropu service VOIP_UDP udp
port-object eq 514
port-object eq 1194
port-object eq 3480
port-object range 49000 50000
access-list TESTACL permit tcp any any object-group VOIP_TCP
access-list TESTACL permit udp any any object-group VOIP_UDP
is this what you are looking for ?
vikram_anumukonda Tue, 03/03/2009 - 07:53
sorry mark, I didn't get the static part of your question.
which code are you running btw ?
