The account number can not be recognized
Mar 2nd, 2009
Hi, I have one question. I wanted to call local service number to pay my bill with IP phone. After getting through the call, i input the account number, but it doesn't be recognized by peer's IVR system. This issue happens occasionally. Anyone knows
1/ how to confirm the IP phone send out the correct number?
2/ how to confirm the voice gateway receive and send out the correct number?
3/ Another ideas?
CUCM 6.1 IP phone 7961.
Thanks. Leo
Jaime Valencia Tue, 03/03/2009 - 04:47
  • Cisco Employee,
  • Hall of Fame,
    2011
1) cucm trace
2) debugs depending the interface
java
if this helps, please rate
Nicholas Matthews Tue, 03/03/2009 - 05:18
  • Red, 2250 points or more
Hi Leo,
My best guess is that you're hitting a bug a filed on duplicate DTMF from the IP phone: CSCsv04751
Try using the speakerphone or a headset and see if you can still reproduce the problem. You can try calling something like the TAC hotline option 2, and have the IVR play the digits back to you. If you're on your handset and you press the button down a little longer than normal, you may get duplicate DTMF.
This happens on phone loads 8.4.1 and 8.4.1 SR1. Anything higher than that and the issue is fixed.
hth,
nick
