IOS Upload
Answered Question
Mar 2nd, 2009
Thanks all in advance,
In XYZ site network there are multiple cisco 2950 switches, Unfortunatly I could not able to connect to the TFTP server from this switch, all other are succesfull. Is there any way that I copy the IOS image from other cisco 2950 switch flash to this switch.
FYI, I have intsalled the TFTP server on the machine where this switch can reachable and uploaded successfully.
My question is Can we copy the IOS image one switch flash to other switch flash(similar Model, Image and every thing)... :-)
Ranga
Correct Answer by Giuseppe Larosa about 8 years 1 month ago
Hello Ranga,
routers can act as tftp server with the command
tftp-server
I've checked command reference for 2950 last release and I didn't find it
see
http://www.cisco.com/en/US/docs/switches/lan/catalyst2950/software/release/12.1_22_ea11x/command/reference/cli3.html
So I think it is not supported.
However, I think you can use as TFTP server also a router placing the switch image on its flash and configuring it as ttfp-server for that file
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Correct Answer
Giuseppe Larosa Mon, 03/02/2009 - 23:36
  • Hall of Fame,
    Founding Member
Hello Ranga,
tftp-server
see
Hope to help
Giuseppe
Leo Laohoo Tue, 03/03/2009 - 13:53
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
I've done this several times.
You have two choices:
1. If you are only copying one file, like the .bin file, I suggest using the "copy tftp:/// flash:"
2. If you are extracting the .TAR file, you can use "archive tar /x tftp:/// flash: "
Hope this helps.
Leo Laohoo Tue, 03/03/2009 - 14:26
  • Hall of Fame,
    2017 LAN, Wireless
Hope this helps.
