Cisco neighbour change message
Mar 3rd, 2009
One of my Cisco switches gets the following two messages in the lsystem logs:
%DUAL-5-NBRCHANGE: IP-EIGRP(0) 1: Neighbor x.x.x.x (Vlanx) is down: holding time expire
%DUAL-5-NBRCHANGE: IP-EIGRP(0) 1: Neighbor x.x.x.x (Vlanx) is up: new adjacency
It happens quite often with the same two devices, but doesn't seem to affect anything.
Can someone explain what the message means and the possible implications?
jeff.kish Tue, 03/03/2009 - 13:29
Hi RVirdi!
You might find better assistance in the Routing/Switching forums, as most people in here are more focused on wireless issues.
This message simply means that your EIGRP neighbors are having connectivity problems. EIGRP has a timeout function that will drop a neighbor if a Hello isn't received in a certain amount of time. You should check their connection and replace any hardware/cabling that might be defective between them.
