03-03-2009 01:13 AM - edited 03-15-2019 04:34 PM
I'm using Cisco Unity Connection 2.x.
The number of licenses for Voicemail, for example, is 200 users and currently run-out, and I have the new 50 additional users need to use IP Phone. Is it possible to transfer call from Auto Attendant to these non-VM-users?
Thanks and best regards,
Solved! Go to Solution.
03-03-2009 04:29 AM
yes but you need to do so from a system transfer, call handlers, subscribers, etc only recognize DNs that exist in CUC as valid transfer options
system transfer allows you to dial ANYTHING that is within the restriction tables
java
if this helps, please rate
03-03-2009 04:29 AM
java
