03-03-2009 02:23 AM - edited 03-11-2019 07:59 AM
I have a problem, in that servers on vlan 111 are intermitent in communicating them selve.
This vlan 111 is trunked with vlan 100 to pix gB-ethr3. Th server gateways are the vlan111 on the pix. (v100 physical, v111 logical, only one switch 4948 is connecting to the two failover pix GB-ether3.
Why is the local communication intermittent.
Note: The server team thinks that the pix trying to do ARP for evrything. What to look for to reason this.
Thanks in advance.
Solved! Go to Solution.
03-03-2009 07:47 AM
disabling proxyarp just on the inside interface should do the job for you ( sysopt noproxyarp inside - stops PIX answering for the ARP requests coming from the inside interface ), as that's the network where you have got intermittent connectivity.
but it's worth trying , if the issue persists.
03-03-2009 03:03 AM
what version of code are you running ?
pasting your code might help .
03-03-2009 06:24 AM
Hi Vikram,
Thank you.
PIX Version 6.3 is used.
and I stopped the proxy-arp function on the pix interface and it looks like it is working.
03-03-2009 07:12 AM
that's what i was guessing too.
I think you will have to disable the proxy-arp thing - If I am not wrong.
"The fix is to turn off proxy-arp for this interface. "sysopt noproxyarp inside" stops PIX answering for the ARP requests coming from the inside interface "
I read this in a book
appreciate you replying to the thread :)
03-03-2009 07:34 AM
Thanks for that.
When i fied the inside by stopping proxy arp, suddenly the outside interface is trying to assist with it's proxy arp.
I'm planning to stop proxy-arp on the ouside. i do not know if this will affect any other interfaces as there is a lot of other interfaces on this pix.
Should i go for no-proxing on the outside/
03-03-2009 07:47 AM
