Video Conferencing HELP
Mar 3rd, 2009
Can anyone help me find a solution for this request that i have. don't have experience at all in Video Conferencing solutions so a help from any one would be perfect.
Technical requirements Unit A
1.1.1 Video unit
Each unit must be controllable from opposite if
connection is hooked (camera control and audio)
Online broadcasting minimum 25 fr/sec
DSL, LAN, WLAN, ISDN (minimum 6 lines)
Enhanced encryption IEEE 802.1x and H.235
authentication
Digital Interface for Home PC to present
electronically documents (network function or
USB or similar)
Interface for multiple video sessions between
minimum 3 points
Interface to connect minimum 4 LCD flat screen
monitors and video beamer
Control touch panel to control video, audio and
periphery
1.1.2 Camera
1 remote control dom camera minimum 270° for
large rooms (min. 100 m²)
Remote control unit
Enhanced zoom function for large rooms
(minimum 5 m distance)
1 tripod for each dom camera to reach minimum
1.75 m height
Remark: tripod only in case if camera is not set top system
1.1.3 Audio unit
Minimum 4 conference microphones
Mutable
Echo reducing
Switches
LED control
Extension cable minimum 8 m
Enhanced encryption (see 3. common standards)
Additional In and out interfaces to connect
recorder or other video/audio system components
Minimum 2 Active loudspeakers sufficient for
room minimum 120 m²
80 Hz-10KHz/ max 89dB/ 600 Ohm
1.1.4 Visualization
1 Portable High resolution video beamer
Minimum 4 LCD flat screen minimum 21”
monitors for clients
1 LCD control monitor minimum 17” for operator
DVI/PCI
