ACE: Virtual Server (VMWARE) running on ACE
Mar 3rd, 2009
I have 2 servers to do loadbalance. they are running VMWARE, they have 4 servers inside of real server. each vmware server only has 1 port connected to Switch, if I want to balance one of them? how do I do?
Best Regards
ciscocsoc Tue, 03/03/2009 - 05:50
  • Silver, 250 points or more
It shouldn't make any difference whether the servers are real or virtual. The ACE works on IP addresses and VLANs. How you configure the context will depend on your network. You may need to use source NAT or you might be able to just use the network as is. It all depends on how you have configured your network.
You'll need to balance across real physical servers to maximise resilience though.
Cathy
