Migrate Cisco 3600 to Cisco 7200
Mar 3rd, 2009
Is it feasible replace a 3600 platform to a 7200 one?
What is the benefit?
What is the best track to accomplish that replacement?
Is there a document to help me on that?
Jon Marshall Tue, 03/03/2009 - 07:41
Andy
It is certainly feasible to do this although you may not necessarily need to go to a 7200 platform. A lot depends on what you are replacing the 3660 for, ie. is it because it is EOS/EOL ?
Attached is a useful pdf that compares performance between router platforms, should give you some idea of what a comparative router would be.
Jon
andy_goes Tue, 03/03/2009 - 08:11
Jon,
That's great!
By the way, do you have a document or a table that compare the card or suggest what card can I use to replace another one? (i.e.: In 3640/60 we use one NM-8A/S we can use a ??? in a 7200-NPE-G2)
Thank you so much.
Jon Marshall Tue, 03/03/2009 - 08:26
Andy
I don't know of such a doc but the easiest way to view which cards are supported with which router is to go to the Product Page for the specific product. In case you're not sure how to get to those pages -
From Cisco homepage select "Products & Services" from along the bar at the top of the web page. From there select "Routers" and then select the router you are interested in. When that router page comes up scroll to the bottom and then choose the "Relevant Interfaces and Modules" link.
Jon
Paolo Bevilacqua Tue, 03/03/2009 - 12:19
For which purpose are you using the NM-8A/S ?
If you desire professional consultancy for all your cisco needs, contact me at the address present in my profile.
Joseph W. Doherty Tue, 03/03/2009 - 17:44
For a NM-8A/S, Table 8 in https://www.cisco.com/en/US/prod/collateral/routers/ps274/product_data_sheet09186a0080091b8b.html notes it's supported in both the 2800 and 3800 series, although both the 4 and 8 port versions are EOS. (The 16 port NM or HWIC variants appear still current.)
Don't believe any NM card supported in the 7200 series. Further, don't see a similar featured PA card for the 7200 series. (If true, likely because a 7200 isn't positioned as an access server or for low speed WAN aggregation.)
If you study Jon's reference, you'll see a 2811 or better offers performance equal or better than a 3660. Unless you need a large increase in performance, you might not need to jump into the 7200 series. If your existing 36x0 performance was alright, an 1800 series might suffice too.
