Constant errors on WAN interface
Mar 3rd, 2009
I receive constant errors on the WAN interface, I have completely replaced the router, however still see errors. Telcom says the circuit is fine, I not sure.
Could this be a result of an overscribed T-1 circuit?
Ver:Cisco Internetwork Operating System Software
IOS (tm) C2600 Software (C2600-IPBASE-M), Version 12.3(6a), RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Fri 02-Apr-04 19:17 by kellythw
Image text-base: 0x80008098, data-base: 0x80ECF498
ROM: System Bootstrap, Version 12.2(8r) [cmong 8r], RELEASE SOFTWARE (fc1)
Output:Serial0/0 is up, line protocol is up
Hardware is PQUICC with Fractional T1 CSU/DSU
Description: $ES_WAN$$FW_OUTSIDE$
Internet address is 192.168.179.14/28
MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec,
Encapsulation PPP, LCP Open
Open: IPCP, loopback not set
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 2d10h
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 3
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 1000 bits/sec, 1 packets/sec
5 minute output rate 1000 bits/sec, 2 packets/sec
4306351 packets input, 2388270494 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
20541 input errors, 645 CRC, 19220 frame, 0 overrun, 0 ignored, 676 abort
2329135 packets output, 149119737 bytes, 0 underruns
2 carrier transitions
DCD=up DSR=up DTR=up RTS=up CTS=up
Adam Frederick Tue, 03/03/2009 - 11:07
  • Bronze, 100 points or more
You could try a 12.4 IOS image as I've seen bugs in IOS' with certain VWIC/WIC cards.
On a different note, I see you cleared the counters 2 days ago. The errors on your interface really aren't that significant over that time frame.
Are you experiencing any data loss? Timeouts?
Also, I show 2 carrier transitions, those can usually be blamed on the carrier depending on setup.
Could you print the info from your t1 controller so we can see exact error info?
FWWITINET Tue, 03/03/2009 - 11:26
Here is the print out of "sh cont serial":
sh contr serial0/0
Interface Serial0/0
Hardware is PowerQUICC MPC860 with Integrated FT1 CSU/DSU module
TX and RX clocks detected.
idb at 0x8198F2B8, driver data structure at 0x81997054
SCC Registers:
General [GSMR]=0x2:0x00000030, Protocol-specific [PSMR]=0x8
Events [SCCE]=0x0000, Mask [SCCM]=0x001F, Status [SCCS]=0x06
Transmit on Demand [TODR]=0x0, Data Sync [DSR]=0x7E7E
Interrupt Registers:
Config [CICR]=0x00367F80, Pending [CIPR]=0x00008000
Mask [CIMR]=0x40204000, In-srv [CISR]=0x00000000
Command register [CR]=0x600
Port A [PADIR]=0x0000, [PAPAR]=0xFFFF
[PAODR]=0x0000, [PADAT]=0xE7FC
Port B [PBDIR]=0x0180F, [PBPAR]=0x0000E
[PBODR]=0x00000, [PBDAT]=0x3E77D
Port C [PCDIR]=0x00C, [PCPAR]=0x000
[PCSO]=0x020, [PCDAT]=0xFC2, [PCINT]=0x00F
Receive Ring
rmd(680126B0): status 9000 length 34 address 5D6C424
rmd(680126B8): status 9000 length 34 address 5D6AA24
rmd(680126C0): status 9000 length 34 address 5D6FEA4
rmd(680126C8): status 9000 length 34 address 5D6CAA4
rmd(680126D0): status 9000 length 36 address 5D6CAA4
rmd(680126D8): status 9000 length 34 address 5D6D124
rmd(680126E0): status 9000 length 34 address 5D6A3A4
rmd(680126E8): status 9000 length 36 address 5D6BDA4
rmd(680126F0): status 9000 length 124 address 5D6D7A4
rmd(680126F8): status 9000 length 5E2 address 5D6EB24
rmd(68012700): status 9000 length 5E2 address 5D69D24
rmd(68012708): status 9000 length 31A address 5D6E4A4
rmd(68012710): status 9000 length 34 address 5D689A4
rmd(68012718): status 9000 length 34 address 5D6F1A4
rmd(68012720): status 9000 length E address 5D70524
rmd(68012728): status 9000 length 4A address 5D68324
rmd(68012730): status 9000 length 34 address 5D6DE24
rmd(68012738): status 9000 length 34 address 5D696A4
rmd(68012740): status 9000 length 34 address 5D66924
rmd(68012748): status 9000 length 34 address 5D67624
rmd(68012750): status 9000 length 34 address 5D6B724
rmd(68012758): status 9000 length 36 address 5D6F824
rmd(68012760): status 9000 length 34 address 5D662A4
rmd(68012768): status B000 length 34 address 5D66FA4
Transmit Ring
tmd(68012770): status 5C00 length 244 address 5C04594
tmd(68012778): status DC00 length 244 address 5C04BD4
tmd(68012780): status 5C00 length EF address 5DA2554
tmd(68012788): status 5C00 length 2C address 5D1D06A
tmd(68012790): status 5C00 length C address 5D6DE24
tmd(68012798): status 5C00 length 2C address 5D1A96A
tmd(680127A0): status 5C00 length 34 address 5D2046A
tmd(680127A8): status 5C00 length 2C address 5D2936A
tmd(680127B0): status 5C00 length 2C address 5D376EA
tmd(680127B8): status 5C00 length 34 address 5D439EA
tmd(680127C0): status 5C00 length 2C address 5D3636A
tmd(680127C8): status 5C00 length 2C address 5D3086A
tmd(680127D0): status 5C00 length C9 address 5D28CEA
tmd(680127D8): status 5C00 length 2C address 5D42CEA
tmd(680127E0): status 5C00 length 2C address 5D3AAEA
tmd(680127E8): status 7C00 length 2C address 5D25F6A
tx_limited=0(16)
SCC GENERAL PARAMETER RAM (at 0x68013C00)
Rx BD Base [RBASE]=0x26B0, Fn Code [RFCR]=0x18
Tx BD Base [TBASE]=0x2770, Fn Code [TFCR]=0x18
Max Rx Buff Len [MRBLR]=1548
Rx State [RSTATE]=0x18008440, BD Ptr [RBPTR]=0x2740
Tx State [TSTATE]=0x18000548, BD Ptr [TBPTR]=0x27A0
SCC HDLC PARAMETER RAM (at 0x68013C38)
CRC Preset [C_PRES]=0xFFFF, Mask [C_MASK]=0xF0B8
Errors: CRC [CRCEC]=1326, Aborts [ABTSC]=1733, Discards [DISFC]=0
Nonmatch Addr Cntr [NMARC]=0
Retry Count [RETRC]=0
Max Frame Length [MFLR]=1608
Rx Int Threshold [RFTHR]=0, Frame Cnt [RFCNT]=38554
User-defined Address 0000/0000/0000/0000
User-defined Address Mask 0x0000
buffer size 1524
PowerQUICC SCC specific errors:
1102 input aborts on receiving flag sequence
0 throttles, 0 enables
0 overruns
0 transmitter underruns
0 transmitter CTS losts
631 aborted short frames
WAT_Sec_Cisco1841_01#
paolo bevilacqua Tue, 03/03/2009 - 12:11
  • Hall of Fame,
    Founding Member
Hi, despite whatever telco swears, it's a faulty circuit. Have them test it using a BERT generator in front of you.
FWWITINET Tue, 03/03/2009 - 12:13
Is that from past experience or from my description and past experience?
Leo Laohoo Tue, 03/03/2009 - 12:46
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Paulo is right. Carriers will always swear by their mother/grandmother that their gears are OK ... until one demands a Bit Error Rate (BER) test.
paolo bevilacqua Tue, 03/03/2009 - 13:18
  • Hall of Fame,
    Founding Member
22 years of experience of which almost 10 at cisco, in multiple countries.
And I've heard telcos "lying" at least once a week.
Actually it's not that they lie purposely, it's just that they think they know better.
