ASA 5505 base liscense - 10 inside hosts?
Answered Question
Mar 3rd, 2009
Hi all
I would like to know what exactly means the restriction aplied with base license that comes with ASA 5505 regarding inside hosts.
I've readed that every host connecting from inside to outside (internet access and so son) counts as one, but all host behind my ASA (arround 25) can properly access to the internet.
Thank you
Miquel
Correct Answer by Ivan Martinon about 8 years 3 months ago
This restriction means that only 10 SIMULTANEOUS IP addresses (hosts) can connect through the firewall at a specific time. Check the "show local-host" this will tell you the current connections in use.
Overall Rating: 5 (1 ratings)
Correct Answer
Ivan Martinon Tue, 03/03/2009 - 10:18
  • Cisco Employee,
