PIX 515E
Mar 3rd, 2009
I'm having some troubles setting up a new firewall. (I'm new to firewalls)I've got the unit up with configured IP addresses on inside and outside. Downloaded and installed ASDM software. I can't seem to get it to pass traffic.
The unit is being used to secure one network from the rest of our company network.
Inside interface is 10.50.241.1/24
The PIX will be the gateway on this network.
Outside interface is 10.48.16.2/20
Gateway on the outside network is a Cisco 6500 MSFC 10.48.16.10 which connects to the rest of the company.
Thanks, Dave
I have included a show run:
PIX Version 7.2(2)
hostname pixfirewall
domain-name default.domain.invalid
enable password 8Ry2YjIyt7RRXU24 encrypted
names
name 10.48.0.0 GAC
name 10.48.16.0 Plant
dns-guard
interface Ethernet0
nameif outside
security-level 0
ip address 10.48.16.2 255.255.240.0
interface Ethernet1
nameif inside
security-level 100
ip address 10.50.241.1 255.255.255.0
interface Ethernet2
shutdown
nameif intf2
security-level 4
no ip address
passwd 0aywtm/YUv1U3jNB encrypted
ftp mode passive
dns server-group DefaultDNS
same-security-traffic permit intra-interface
object-group protocol TCPUDP
protocol-object udp
protocol-object tcp
access-list ping_acl extended permit icmp Plant 255.255.240.0 any
access-list outside_access_in extended permit icmp Plant 255.255.240.0 10.50.241.0 255.255.255.0
access-list outside_access_in extended permit icmp GAC 255.255.240.0 10.50.241.0 255.255.255.0
pager lines 24
logging asdm informational
mtu outside 1500
mtu inside 1500
mtu intf2 1500
icmp unreachable rate-limit 1 burst-size 1
icmp permit any outside
icmp permit any inside
asdm image flash:/asdm-524.bin
asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 10.50.241.0 255.255.255.0
access-group ping_acl in interface outside
route outside 0.0.0.0 0.0.0.0 10.48.16.10 1
router rip
network 10.0.0.0
version 2
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
http server enable
http 10.50.241.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
snmp-server enable traps snmp authentication linkup linkdown coldstart
no sysopt connection permit-vpn
telnet Plant 255.255.240.0 outside
telnet GAC 255.255.240.0 outside
telnet 10.50.241.0 255.255.255.0 inside
telnet timeout 5
ssh timeout 5
ssh version 1
console timeout 0
dhcpd dns 10.50.1.46 171.74.105.58
dhcpd wins 171.74.162.21 171.74.105.58
dhcpd ping_timeout 750
dhcpd auto_config outside
dhcpd address 10.50.241.101-10.50.241.199 inside
dhcpd enable inside
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns migrated_dns_map_1
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect http
inspect netbios
inspect rsh
inspect rtsp
inspect skinny
inspect esmtp
inspect sqlnet
inspect sunrpc
inspect tftp
inspect sip
inspect xdmcp
service-policy global_policy global
prompt hostname context
Cryptochecksum:d8ad1ad3a52aec150a71ccd959a2681a
: end
asdm location GAC 255.255.240.0 inside
asdm history enable
isagonza Tue, 03/03/2009 - 09:39
Try changing your PAT:
Enter these commands:
no global (outside) 1 interface
no nat (inside) 0 10.50.241.0 255.255.255.0
nat (inside) 1 10.50.241.0 255.255.255.0
clear xlate
About acls: access-list outside_access_in extended permit icmp Plant 255.255.240.0 10.50.241.0 255.255.255.0
You are trying to ping your hosts in the inside from Plant and GAC (located in the outside), you will not be able to do this since you are USING PAT, hence hiding your inside network, so whenever you try to ping any host in 10.50.241.0 you will not reach it from the outside.
Try entering
access-list outside_access_in extended permit icmp any any
so you can test pinging from any host in the inside to anything in the outside, but you won't be able to ping from the outside to the inside
And one last observation:
You will not be able to telnet to the outside interface unless you use IPSec, this is because telnet will send everything in clear text, and doing this in the outside interface will be insane!!
dklewe Tue, 03/03/2009 - 15:09
Thanks for the advice.
I found a routing issue as well. Things were getting out and not able to come back.
It's up and working now.
Thanks again, Dave
