ASA5540 ver.7.2(2) RSA Authentication Manager 7.1
Mar 3rd, 2009
Good evening,
I'm searching documentation to verify if my ASA appliance support as RADIUS Server, the solution RSA Authentication Manager 7.1.
I assumed which with RADIUS Server authentication support provide by ASA software, is possible.
I've find also an a RSA SecureID Implementation Guide that I'm attached; in this document you should read about solution in conjuction with ASA ver.7.0.1 and RSA Authentication Manager 6.1
I'm verifing to don't have problem in future with compatibility between twe two brands.
Any information, link, or user guide are welcomed!
Cheers
Davide Sacca'
Daniel Laden Wed, 03/04/2009 - 21:01
  • Cisco Employee,
According to the ASA 8.0 documentation
http://www.cisco.com/en/US/docs/security/asa/asa80/configuration/guide/aaa.html#wp1057621
SDI Version Support
The security appliance supports SDI Version 5.0 and 6.0.
If you configure the RSA device as a SDI, you may have issues getting support as 7.x is unsupported. If RSA device is configured as a RADIUS device, you should not have a problem.
