GSS HTTP-Head
Mar 3rd, 2009
I am trying to create a keepalive using HTTP-Head
port 443
path = /status.jsp
Can the GSS support the jsp files as a keepalive?
If web server using siteminder for authentication will the GSS be able to do an HTTP-Head test? If not is there a work around?
Syed Iftekhar Ahmed Tue, 03/03/2009 - 22:12
  • Blue, 1500 points or more
your problem is that HTTP keepalive only sends HTTP keeplalives. It would not send an SSL handshake and encrypt the request in HTTPS.
Syed iftekhar Ahmed
