Edison Ortiz Tue, 03/03/2009 - 10:15
  • Hall of Fame,
    Founding Member
You haven't mentioned the switch in question, but switch<->switch connectivity is automatically enabled with straight-thru cable as long as both switches support auto-mdix.
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_46_se/configuration/guide/swint.html#wp1193977
Keep in mind, configuring the speed/duplex on the switchports will disable auto-mdix support.
HTH,
__
Edison.
Leo Laohoo Tue, 03/03/2009 - 13:43
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Edison is right. What is the model of your appliance?
As a rule of thumb, connect a cross-over cable when you connect a switch to another switch.
However, if you have the newer generation of switches: 2960/2970/2975, 3560, 3750, these appliances now come with MDI/MDIX enabled.
