Renumbered my switch now I'm seeing high loads on interface
Answered Question
Mar 3rd, 2009
  • Purple, 4500 points or more
I renumbered my 3750 switches over the weekend, and the port that my router is connected to is at > 95% load occasionally. I can't run netflow on these switches, so what do you recommend? I need to figure out why this is so high.
GigabitEthernet5/0/5 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 0015.f937.6785 (bia 0015.f937.6785)
Description: IT.glazers.info Core-Router
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
reliability 255/255, txload 144/255, rxload 15/255
Keepalive set (10 sec)
Full-duplex, 100Mb/s, media type is 10/100/1000BaseTX
input flow-control is off, output flow-control is unsupported
Last input 00:00:59, output 00:00:08, output hang never
Last clearing of "show interface" counters 23:32:34
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 6234000 bits/sec, 4097 packets/sec
5 minute output rate 56676000 bits/sec, 6224 packets/sec
309165083 packets input, 48492636223 bytes, 0 no buffer
Received 15889 broadcasts (0 multicasts)
0 watchdog, 1763 multicast, 0 pause input
483806046 packets output, 569122503579 bytes, 0 underruns
The port is trunked to the router, and I haven't noticed it in the past, but it seems that most of the time it's been at least once every 30 minutes that I'm seeing this load. Anything I should look at?
John
Correct Answer by Edison Ortiz about 8 years 4 weeks ago
You can run NetFlow on the router. It should reflect the traffic that is coming from the switch.
__
Edison.
Overall Rating: 5 (1 ratings)
Correct Answer
Edison Ortiz Tue, 03/03/2009 - 13:13
  • Hall of Fame,
    Founding Member
__
Edison.
John Blakley Tue, 03/03/2009 - 13:16
Duh....good point. I've been looking at this stuff way too much today. :-)
John
