Wireless to cover a subdivision
Mar 3rd, 2009
Does anyone have any expereince with rolling out wireless coverage for an entire subdivision? The desired result is indoor and outdoor access. Any thoughts , ideas or suggestions are appreciated. Can it be done in a cost effective manor with Cisco hardware?
All replies rated.
Overall Rating: 5 (1 ratings)
Leo Laohoo Tue, 03/03/2009 - 14:20
For outdoor, you need a Cisco Aironet 1500 Lightweight Outdoor Mesh Access Point (http://www.cisco.com/en/US/products/ps6548/index.html).
For indoors, you can use ... ALOT! For indoor use with alot of corners, use the latest model that also comes with Draft N 2.0, the 1140 (http://www.cisco.com/en/US/prod/collateral/wireless/ps5678/ps10092/datasheet_c78-502793.html).
Before you go and make a decision, make sure you have a Wireless Site Survey conducted. This will enable you and your company deploy the right amount AP at the right location and eliminating un-necessary guess work.
Hope this helps.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
