QoS Problems
Mar 3rd, 2009
I try using MQC and CAR into cisco 3725 following
rate-limit output access-group 100 160000 1500 2000 conform-action continue exceed-action drop
but this rule does not work, and i try the follow rule
access-list 100 permit ip any any
class-map match-all classmap1
match access-group 100
policy-map policymap1
class classmap1
shape average 8000
interface FastEthernet0/0
ip address 10.0.0.121 255.255.255.0
service-policy output policymap1
and does not work either, the result is the same with or without QoS
regards
mikegrous Tue, 03/03/2009 - 15:49
Your configs look correct. How are you basing that this isnt working? Are your show commands (show policy-map int fa0/0) not showing matched data? What are you trying to accomplish. Shaping and police will do to differnt things. Shaping has buffers policing (rate-limit command) does not.
Also in your rate limit command your burst values are quite low. I think they should be 30000 and 60000
(160000/8)*1.5= 30000
30000x2= 60000
http://www.cisco.com/en/US/docs/ios/qos/command/reference/qos_q1.html#wp1015612
r-barbosa Wed, 03/04/2009 - 08:30
hi
yes its showing matched data, I using the dynamips emulator, tested with an Cisco ASA rule MQC and i have worked, then i think the problem is the dynamips. thanks
regards.
