03-03-2009 07:49 PM - edited 03-11-2019 08:00 AM
Hello all,
I'm trying to test new phone-proxy feature and I can't make it work.
Phone shows registering and nothing happens.
I've attached config, it's a copy from Cisco website
Here the debug from debug phone-proxy:
PP: 192.168.1.5/49162 requesting CTLSEP001A6DE7CB1C.tlv
PP: opened 0x4213e156
PP: Data Block 1 forwarded from 192.168.1.10/15995 to 192.168.1.5/49162 ingress ifc Outside
PP: Received ACK Block 1 from Outside:192.168.1.5/49162 to inside:172.18.224.37
PP: Data Block 2 forwarded to 192.168.1.5/49162
PP: Received ACK Block 2 from Outside:192.168.1.5/49162 to inside:172.18.224.37
PP: Data Block 3 forwarded to 192.168.1.5/49162
PP: Received ACK Block 3 from Outside:192.168.1.5/49162 to inside:172.18.224.37
PP: Data Block 4 forwarded to 192.168.1.5/49162
PP: Received ACK Block 4 from Outside:192.168.1.5/49162 to inside:172.18.224.37
PP: Data Block 5 forwarded to 192.168.1.5/49162
PP: Received ACK Block 5 from Outside:192.168.1.5/49162 to inside:172.18.224.37
PP: Data Block 6 forwarded to 192.168.1.5/49162
PP: Received ACK Block 6 from Outside:192.168.1.5/49162 to inside:172.18.224.37
PP: Data Block 7 forwarded to 192.168.1.5/49162
PP: Received ACK Block 7 from Outside:192.168.1.5/49162 to inside:172.18.224.37
PP: TFTP session complete, all data sent
PP: 192.168.1.5/49163 requesting SEP001A6DE7CB1C.cnf.xml.sgn
PP: opened 0x42195542
PP: Received Data Block 1 from inside:172.18.224.37/33820 to Outside:192.168.1.5/49163
Received Block 1
PP: Acked Block #1 from 172.22.161.21/49163 to 172.18.224.37/33820
PP: Received Data Block 2 from inside:172.18.224.37/33820 to Outside:192.168.1.5/49163
Received Block 2
PP: Acked Block #2 from 172.22.161.21/49163 to 172.18.224.37/33820
PP: Received Data Block 3 from inside:172.18.224.37/33820 to Outside:192.168.1.5/49163
Received Block 3
PP: Acked Block #3 from 172.22.161.21/49163 to 172.18.224.37/33820
PP: Received Data Block 4 from inside:172.18.224.37/33820 to Outside:192.168.1.5/49163
Received Block 4
PP: Acked Block #4 from 172.22.161.21/49163 to 172.18.224.37/33820
PP: Received Data Block 5 from inside:172.18.224.37/33820 to Outside:192.168.1.5/49163
Received Block 5
PP: Acked Block #5 from 172.22.161.21/49163 to 172.18.224.37/33820
PP: Received Data Block 6 from inside:172.18.224.37/33820 to Outside:192.168.1.5/49163
Received Block 6
PP: Acked Block #6 from 172.22.161.21/49163 to 172.18.224.37/33820
PP: Received Data Block 7 from inside:172.18.224.37/33820 to Outside:192.168.1.5/49163
Received Block 7
PP: Acked Block #7 from 172.22.161.21/49163 to 172.18.224.37/33820
PP: Received Data Block 8 from inside:172.18.224.37/33820 to Outside:192.168.1.5/49163
Received Block 8
PP: Acked Block #8 from 172.22.161.21/49163 to 172.18.224.37/33820
PP: Received Data Block 9 from inside:172.18.224.37/33820 to Outside:192.168.1.5/49163
Received Block 9
PP: Acked Block #9 from 172.22.161.21/49163 to 172.18.224.37/33820
PP: Received Data Block 10 from inside:172.18.224.37/33820 to Outside:192.168.1.5/49163
Received Block 10
PP: Acked Block #10 from 172.22.161.21/49163 to 172.18.224.37/33820
PP: Unable to get dns response for id 7
PP: Callback, error modifying config file
PP: Unable to CM name addr
PP: Callback required for parsing config file
PP: Client Outside:192.168.1.5/49163 retransmitting request for Config file SEP001A6DE7CB1C.cnf.xml.sgn
PP: opened 0x421fc98e
03-05-2009 11:30 PM
Config:
interface Vlan1
nameif inside
security-level 100
ip address 172.22.161.15 255.255.255.0
interface Vlan2
nameif Outside
security-level 0
interface Ethernet0/0
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
switchport access vlan 2
access-list pp extended permit udp any host 192.168.1.10 eq tftp
access-list pp extended permit tcp any any eq 2000 log
access-list pp extended permit tcp any any eq 2443 log
pager lines 24
logging console debugging
logging buffered debugging
mtu inside 1500
mtu Outside 1500
icmp unreachable rate-limit 1 burst-size 1
static (inside,Outside) 192.168.1.10 172.18.224.37 netmask 255.255.255.255
static (Outside,inside) 172.22.161.21 192.168.1.5 netmask 255.255.255.255
static (inside,Outside) 172.18.224.37 192.168.1.10 netmask 255.255.255.255
static (inside,Outside) 172.22.161.21 192.168.1.5 netmask 255.255.255.255
access-group pp in interface Outside
route inside 0.0.0.0 0.0.0.0 172.22.161.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
dynamic-access-policy-record DfltAccessPolicy
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto ca trustpoint cucm_tftp_server
enrollment self
serial-number
keypair cucmtftp_kp
crl configure
crypto ca trustpoint _internal_myctl_SAST_0
enrollment self
fqdn none
subject-name cn="_internal_myctl_SAST_0";ou="STG";o="Cisco Inc"
keypair _internal_myctl_SAST_0
crl configure
crypto ca trustpoint _internal_myctl_SAST_1
enrollment self
fqdn none
subject-name cn="_internal_myctl_SAST_1";ou="STG";o="Cisco Inc"
keypair _internal_myctl_SAST_1
crl configure
crypto ca trustpoint _internal_PP_myctl
enrollment self
fqdn none
subject-name cn="_internal_PP_myctl";ou="STG";o="Cisco Inc"
keypair _internal_PP_myctl
crl configure
crypto ca certificate chain cucm_tftp_server
certificate crypto ca certificate chain _internal_myctl_SAST_0
certificate _internal_myctl_SAST_1
certificate quit
crypto ca certificate chain _internal_PP_myctl
certificate
quit
telnet timeout 5
ssh timeout 5
console timeout 0
tls-proxy mytls
server trust-point _internal_PP_myctl
ctl-file myctl
record-entry cucm-tftp trustpoint cucm_tftp_server address 172.18.224.37
no shutdown
phone-proxy mypp
media-termination address 172.16.161.20
tftp-server address 192.168.1.10 interface Outside
tls-proxy mytls
cipc security-mode authenticated
ctl-file myctl
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
class-map sec_sip
match port tcp eq 5061
class-map sec_sccp
match port tcp eq 2443
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect netbios
inspect rsh
inspect rtsp
inspect skinny
inspect esmtp
inspect sqlnet
inspect sunrpc
inspect tftp
inspect sip
inspect xdmcp
policy-map pp_policy
class sec_sccp
inspect skinny phone-proxy mypp
class sec_sip
inspect sip phone-proxy mypp
service-policy global_policy global
service-policy pp_policy interface Outside
03-06-2009 02:58 PM
There is a portion of your debug that suggests that the CM is unable to be resolved:
Do you publish your CCM/CUCM by hostname or by IP?
03-08-2009 05:36 PM
Thanks for the point, I've changed hostname to IP address, but the issue still the same.
Phone still shows "Registering".
ASA debug (debug inspect tls-proxy)
Setting SERVER_CLEAR flag in conn
TLSP d4f9bb10: Set up proxy for Client Outside:192.168.1.5/43381 <-> Server inside:192.168.1.10/2443
TLSP d4f9bb10: Using trust point '_internal_PP_myctl' with the Client, RT proxy d4f58f38
TLSP d4f9bb10: Waiting for SSL handshake from Client Outside:192.168.1.5/43381.
TLSP d4f9bb10: --> Proxy Rx 52 bytes
TLSP d4f9bb10: <== Proxy Tx 7 bytes
TLSP d4f9bb10: new event: KILL_FLOW
TLSP d4f9bb10: Tear down proxy for Client Outside:192.168.1.5/43381.
TLSP d4f9bb10: Tear down proxy for Server inside:172.18.224.37/2000.
Any ideas?
03-08-2009 06:18 PM
Try to debug the tftp (debug phone-proxy tftp).
this link maybe helpful...
03-08-2009 08:58 PM
After the deepest troubleshooting, I've found that ASA didn't have 3DES license. After 3DES activation and updating parameters for ssl, it started to work.
Many thanks to all !!!!
