set up date and time on call manager 6.1(2)
rachelau_2005
I am using call manager 6.1(2)
The time on the IP phones are wrong.
I have set up the time zone under the date/time group configuration page on the call manager.
Where can I set the correct date and time on the cisco call manager 6.1(2)?
and how can I synchroize the time betweeo sub and pub for the call manager 6.1(2).
kind regards
Rachel
yes...
In Os administration page of pub > settings > time
rate if useful..
you ca set time in o/s administration page or you can map it to an ntp server
subscriber getting its time from publisher
But for phones you can set ntp reference for phones in administration page
note: In command prompt check
show timezone config
show timezone list
utils ntp config
utils ntp restart
utils ntp start
utils ntp status
if I dont have any ntp server that I can connect to it.. is there any way to just set the date and time on the call manager 6.1 ?
when I was using call manager 4.2.1, I set up the time on the call manager directly previously... is it possible for call manager 6.1(2)?
basically i just need to sychronize the time for pub, sub and unity.
thanks
yes...
rate if useful..
Yes,
its working now, thanks
