CIPC over VPN on ASA no VM
Mar 3rd, 2009
Have CIPC running okay over VPN through ASA 5510. The only issue at this time is when the messages button is pressed, the CIPC calls and connects to voicemail, but no audio is heard.
Knowing what digits to press to access mailbox and listen to messages, I do that on the CIPC and it does retrieve messages, just without sound.
I know it's probably simple, so what am I missing?
CCM 4.2(3)
CIPC 2.1.4
ASA 8.? (cant remember off top of head, and no access at moment. It is 8-something though)
Christopher McAlpin Wed, 03/04/2009 - 15:09
  • Cisco Employee,
I have the same issue with IP Communicator over VPN. If I call in to one of my Unity servers that has a SIP Trunk integration, all is fine. If I call into one doing a Skinny integration, I have no audio.
benharned Wed, 03/11/2009 - 09:36
I can't believe no one else has had this problem and not either solved it or found out it's not possible.
Tommer Catlin Wed, 03/11/2009 - 11:13
  • Green, 3000 points or more
Is your Unity server on a different subnet? Once CUCM hands the call to Unity ports, its Unity and IP phone talking directly. If Unity is not allowed through your ASA, it's probably why.
benharned Wed, 03/11/2009 - 12:01
Unity and CCM are on the same subnet. I am able to ping Unity from the remote computer.
