Setting the "Solved"-flag on a thread
Mar 4th, 2009
Sometimes it happens that I find a solution to my problem on my own. If I have started a thread on the issue, I post the solution. Unfortunately, I can't find a way to mark own replies as "Solved" ?
Overall Rating: 4 (1 ratings)
rob.huffman Fri, 03/06/2009 - 06:19
Hi Kjetil,
This is by design :)
We are not allowed to rate our own posts or mark them as resolved. If we did allow this it would somewhat dilute the validity of the "Rating System".
When you post your resolution,hopefully, many NetPros will rate you for your kind follow-up, but that's as good as it gets when you are the OP (Original Poster).
Keep on posting!
Anonymous (not verified) Mon, 03/23/2009 - 06:58
it would be nice to be able to delete a post.
I seem to submit duplicate posts all the time when this stupid apache error crops up all the time and then have to go back and insert the body.
it makes me cry.
Paolo Bevilacqua Thu, 04/09/2009 - 10:35
When it happens, put your handle in the post. Else we don't even know who this plague is hitting.
John Blakley Fri, 04/24/2009 - 10:26
I second the delete a post comment. It would be good to delete after you post it. You're able to edit it, why not allow the post to be deleted. Right now, I have to edit the post that I just posted, remove all of my text, and I put deleted in the comments. They *might* be deleted on the backend, but I'm not sure.
