WRVS4400N- No Wireless, loud noise from unit
Mar 4th, 2009
I have had my Linksys/Cisco WRVS4400N for just under a year now and recently it started to have some major issues.
1) The wireless completly died on it a few months ago (I have other AP's, but liked the N on this one). I have tested it multiple times with different cards/machines. The network apears and disapears, you can never sucessfully connect. This happens in N-G-B, 10ft away or 100ft away.
2) The unit (V1.0) has started to make a loud buzzing sound. Rather annoying as its in the Bedroom closet.
Is this still under warranty? I bought it from a retailer around 10 months ago, but long lost the reciept.
Thank you.
Marc
tychao Wed, 03/04/2009 - 07:35
The WRVS4400N has a 3 year manufacturers warranty so it appears that you are within the warranty period.  To begin the process, if you are not a registered VAR, please contact our support team at 800-326-7114 so they can authorize a return.
fscharz Tue, 01/12/2010 - 07:37
This can happen with V1 make sure you get as replacement product V2.
