SDM and ZoneBasedFirewall on 3825: How to View Firewall logs?
Mar 4th, 2009
If I read the documentation, I have to go to ACL Editor/Access Rules, and click "Log matches against this entry"
However, my statefull rules are configured under ACL Editor/Firewall Rules, and there I do not have the option "Log matches against this entry".
Any idea?
thx Karien
Alex Yeung Thu, 03/05/2009 - 01:01
can you provide a link? or is in the Help menu in SDM?
Alex Yeung
zenon_electronics Tue, 03/10/2009 - 05:40
Hi, on the ZoneBased Firewall you can see logs. All you have to do, is to manually apply class class-default on every policy map you have defined.
Example:
policy-map type inspect in-out-policy
class class-default
drop log
When you do this to all policy maps, you will see all packets that are droped.
Regards.
