AIP-SSM password recovery
Mar 4th, 2009
Our Client is having 2 ASA firewalls ( 5540 ) along with AIP-SSM modules in it . They are configured for Failover . The OS of ASA is 7 and the OS of IPS is 5.0 . I have read on Cisco website that Password recovery cant be done on IPS modules having 5.0 OS . Is there really no way we can recover its password ?
marcabal Wed, 03/04/2009 - 09:15
  • Cisco Employee,
The password recovery feature is only available with version 6.0 and higher.
With the password recovery feature it will reset the cisco user password back to the default and leave all other configuration of the sensor in place.
With version 5.x you will need to re-image the SSM with a System Image and start from a fresh installation and config.
Any existing configuration will be cleared.
Directions:
http://www.cisco.com/en/US/docs/security/ips/6.2/configuration/guide/cli/cli_system_images.html#wp1231447
System Image location on cisco.com:
http://tools.cisco.com/support/downloads/go/ImageList.x?relVer=6.1%282%29E3&mdfid=280432811&sftType=Intrusion+Prevention+System+%28IPS%29+System+Software&optPlat=&nodecount=2&edesignator=null&modelName=Cisco+ASA+Advanced+Inspection+and+Prevention+%28AIP%29+Security+Services+Module&treeMdfId=278875311&treeName=Intrusion+Prevention+System+%28IPS%29&modifmdfid=null&imname=&hybrid=Y&imst=N&lr=Y
