IPv6 support on management for WLC4404 and AP1131 ?
Mar 4th, 2009
Anyone who know if this works ?
ericgarnel Wed, 03/04/2009 - 06:22
It works fine on the wisms running 4.2.176 & 1252 radios for client traffic. It "should" probably be fine with your setup too.
Keep in mind that it just passes ipv6 traffic and does not actively participate in ipv6.
If you are trying to use it for management of the radios, I do not know;perhaps in 5.x and above it can for management...
Have you read the release notes on the version you are using
skronawithleitner Wed, 03/04/2009 - 10:04
I am running 5.2 on my WiSMs with a dedicated IPv6-only SSID.
Management over IPv6 is not possible at the moment, you even have to give the dynamic interface for that SSID a "dummy"-address - IPv6-addresses and "none" does not work.
IPv6 traffic works however very good then.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
