Tommer Catlin Wed, 03/04/2009 - 09:07
  • Green, 3000 points or more
So if you click to call, the phone goes off hook, but no digits appear, you have the wrong Application dialing rule built. For example, I had an issue with E.164 sting from the Directory.
+14085552000
This was a directory number in AD. Click to call would be in the Application Dialing Rule:
Starts with +
total digits 13
strip out 8 digits
When actually, the + is not a digit, it does not count this. So it's a 12 digit string. Once I adjusted this, then on CUPS restarted the Sync service.. it worked.
So if you are getting a plank, it's the wrong Application Dialing Rule or issue.
askq2forum Wed, 03/04/2009 - 14:53
Tommer, it was a dial pattern issue on CCM, thanks for your reply very useful as always...Jag
