BGP not running on 2801 Router
AjokuKelechi
I am practicing with a 2801 router for my ccnp but when I enter the config command
Router bgp 100 it gives me an error message of (Protocol not in Image)
Please what should I do?
Mark Yeates
Level 7
Level 7
The (Protocol not in Image) error means that the feature set of your IOS does not support BGP. I would suggest upgrading the feature set to advanced IP services on your router for your studies. Feature set upgrades can be purchased through your Cisco partner. Can you please post the "show version" command to confirm.
HTH,
Mark
c.captari
Hi.
If you have access to download section in Cisco.com you can use
Cisco Feature Navigator
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
This helps you search IOS images by features you want (you use drop down boxes for selecting exactly what you need)
