MARS Doesn't display attack diagram
Mar 4th, 2009
Hi Friends,
I have added the devices in the DC to the CS MARS. Following are the devices added and discovered
1) 6509 switch
2) FWSM module
3) IPS Sensor
4) branch router
but the issue is iam not getting the attack diagram in the dash board... it is just blank.
any help is appreciated.
Ravi
Farrukh Haroon Fri, 03/06/2009 - 22:37
  • Red, 2250 points or more
Attack diagarm is usually visible if both endpoints (source/destination) are available on the map. If the attack involves some internet address the diagram will not display. Try to check any attack which involves source/destination from the local network.
Farrukh
Mubasher Sultan... Tue, 05/05/2009 - 00:46
How can we check the CPU Utilization & Memory Utilization on the box?
Did you get any reply from the TAC about the memory leak?
Appriciate your help.
