Single peer address for several vpn peers.
Mar 4th, 2009
Hi everyone,
I apologise for posting this thread in this forum. I have also posted it in the vpn forum but find I always get a much quicker response here.
I wonder if anyone can help me please. I am setting up vpn tunnels between my site and 3 other sites (there is no connectivity required between these 3 sites).
I am using a Cisco 7301 as my endpoint and have a single IP address that all three sites have to use as their peer address to connect with my site.
Please help with the configuration of this, I am told it is possible to configure this but would like some assistance, any sample configs or pointers in the right direction will be gratefully received.
Cheers,
Martha
Overall Rating: 5 (1 ratings)
Giuseppe Larosa Wed, 03/04/2009 - 07:19
Hello Martha,
on your side you need to configure a crypto map with three blocks
something like
crypto isakmp key shared_pwd_C1 address public-peer-1
crypto isakmp key shared_pwd_C2 address public-peer-2
crypto isakmp key shared_pwd_C3 address public-peer-3
then three blocks with different sequence number like
crypto map VPN_MAP 1000 ipsec-isakmp
description peer1
set peer public-peer-1
set transform-set AES128
match address 2059
reverse-route
crypto map VPN_MAP 1010 ipsec-isakmp
description peer2
set peer public-peer-2
match address 2060
reverse-route
crypto map VPN_MAP 1030 ipsec-isakmp
description peer3
set peer public-peer-3
match address 2061
reverse-route
the crypto map is then applied on the outgoing interface
see
http://www.cisco.com/en/US/docs/ios/security/configuration/guide/sec_cfg_vpn_ipsec_ps6350_TSD_Products_Configuration_Guide_Chapter.html#wp1047631
you need also to define the transform set that specify what encryption to use
Hope to help
Giuseppe
mfawehin Wed, 03/04/2009 - 22:16
Wow, as always Giuseppe thank you for your comprehensive, examplary post. I will amend the sample you sent and let you know how I get on. Again, many thanks, Martha.
Giuseppe Larosa Thu, 03/05/2009 - 00:00
Hello Martha,
I took this example from my production network with some changes.
the reverse-route command provides reverse-route injection that allows to create static routes to remote site during the ipsec tunnel is up.
We have a Stateful IPsec pair or routers that are two C7206VXR with NPE-G2 and 12.4(20)T advance_enterprise
I think the command can help in a redundant environment
see
http://www.cisco.com/en/US/docs/ios/security/command/reference/sec_r2.html#wp1040683
if I remember correctly you are going to use a PIX pair I'm not sure the command is available.
Hope to help
Giuseppe
mfawehin Thu, 03/05/2009 - 01:20
Thanks Giuseppe.
The pair is actually 7301 routers so I'll check but I'm almost certain it'll be fine.
