Problem ip route
Mar 4th, 2009
I have the next configuration in router R1
Router R1:
inte fas0/1
ip address 172.20.10.202 255.255.255.248
int fas 0/0
ip address 172.17.240.1 255.255.255.0
ip route 0.0.0.0 0.0.0.0 fas0/1
Router r1 connect with other router r2, i don't have the configuration of router r2.
I can do ping to r2 172.20.10.201 in router r2, since router r1, but pc in net 172.17.240.0/24 can't do ping to r2 172.20.10.201
The connection is:
pc-----fe0/0-r1-fe0/1------r2
I need to do any configuration additional in r1
Overall Rating: 5 (2 ratings)
Edison Ortiz Wed, 03/04/2009 - 06:50
  • Hall of Fame,
    Founding Member
No, you don't need any additional configuration on Router 1.
Router 1 has a default route towards R2. All packets from Router 1 will go to R2.
The problem is R2 does not have any routing information back to R1.
ip route 172.17.240.0 255.255.255.0 172.20.10.202 on R2 will fix the problem.
HTH,
__
Edison.
Jon Marshall Wed, 03/04/2009 - 06:52
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
"I need to do any configuration additional in r1"
No, you need a route added to R2 for 172.17.240.0/24 pointing back to R1.
Or you could use NAT if you can't access R2 ie. On R1
int fa0/0
ip nat inside
int fa0/1
ip nat outside
access-list 101 permit ip 172.17.240.0 0.0.0.255 host 172.20.10.202
ip nat inside source list 101 interface fa0/1 overload
Jon
