03-04-2009 07:07 AM - edited 03-15-2019 04:36 PM
Hi Guys,
My Customer is trying active the ISDN in a router 2811 and we are found the following problem: The ISDN active the 03 levels, but, in the router don't appear the voice-port. I verify the configuration and it's Ok. The router is with version Version 12.4(23).
Any Idea?
Wilson Santana
Solved! Go to Solution.
03-04-2009 10:11 AM
Correct, NM-1CE1T1-PRI does not support voice.
03-04-2009 10:00 AM
Ola' Wilson,
Can you try an IOS voice version ?
Since when you've PRI in Brasil ?
03-04-2009 10:05 AM
03-04-2009 10:11 AM
