load-sharing per-packet with EIGRP
Mar 4th, 2009
Hi.
How can I load balance, per packet, between 2 fast-ethernet interfaces on a 2811 router running EIGRP, from the same IP source to the same IP destination?
Both links have the same metric and shown in the routing table.
Danny.
Overall Rating: 5 (1 ratings)
Giuseppe Larosa Wed, 03/04/2009 - 07:31
  • Hall of Fame,
    Founding Member
Hello Danny,
EIGRP provides two equal cost paths to CEF.
To perform per packet load-sharing
int fx/y
ip load-sharing per-packet
int fx/z
do it on both routers
be aware that some types of traffic like VoIP can be severely affected by per packet load balancing
so per-packet can be an improvement or a worse problem
Hope to help
Giuseppe
