HA with 2 Switches
Answered Question
Mar 4th, 2009
Hi Everybody,
I have a webserver which is very critical. So it connected to Cisco 2960 Switch. All the desktops are connected to this server and access web site.
But when the switch fails the webserver is unavailable. so i want introduce another 2960 switch and like to connect as per the diagram attached here.
Kindly educate me,
1. Whether this is the right method or best practice to achieve my requirement.
2. what configuration i have to do in switches?
Kindly guid me
R.B.Kumar
Correct Answer by Giuseppe Larosa about 8 years 3 weeks ago
Hello R.B. Kumar,
>> Do i have to do any configuration in Switches?
nothing special you can use spanning-tree portfast on the ports that need to be om the same Vlan
the server teaming must be of type active/standby only one NIC must speak at a given time
STP shouldn't play any role here the active NIC is the one used in both directions thanks to MAC address learning function
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Giuseppe Larosa Wed, 03/04/2009 - 09:00
  • Hall of Fame,
    Founding Member
Hello R.B. Kumar,
the server has to be configured for active/passive teaming
the two switch ports have to be on the same vlan
you cannot use both NICs at the same time with this setup
Hope to help
Giuseppe
hclisschennai Thu, 03/05/2009 - 07:33
Hi Giuseppe,
Thanks for your reply. your reply helped me.
I will take care of teaming the server NICs.
Whether STP plays a role here?
R.B.Kumar
Correct Answer
Giuseppe Larosa Thu, 03/05/2009 - 08:44
  • Hall of Fame,
    Founding Member
Hello R.B. Kumar,
Hope to help
Giuseppe
