CM 7.0 cluster licensing
Answered Question
Mar 4th, 2009
We have to build a CM 7.0 cluster based on MCS-7835-H2 servers consisting of the following components:
- One Publisher Server
- Four active Subscribers
- Two redundant Subscribers;
- Two TFTP Servers.
The total number of MCS-7835-H2 servers is 9.
How many node licenses (LIC-CM7.0-7835=) is required in this configuration?
Correct Answer by Rob Huffman about 8 years 1 month ago
Hi ,
Just to add a touch to the great tips from David and Java (+5 points each guys!) I always thought the answer would be 7 but Chris corrected me in this recent thread and the answer in this instance is 9 Node Licenses will be required;
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Telephony&topicID=.ee6c829&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.2cc2ab2c/1#selected_message
Hope this helps!
Rob
Overall Rating: 4.5 (6 ratings)
david-lima Wed, 03/04/2009 - 10:33
  • Bronze, 100 points or more
Hi, I understand that you can only have 1 PUB and 8 Subscribers, it means a maximum of eight nodes can be used for call processing (running the Cisco
Unified Communications Manager service) and the Pub server running only the TFTP services.
So, you can have only 8 node licenses, for each call-processing CUCM server within the cluster.
Hope this help
David
david-lima Wed, 03/04/2009 - 10:35
Remember that there are 3 types of license:
There are three types of licenses.
- Software license is required for using CUCM 6 software.
- Device license units required for devices (phones).
- Node licenses required for each call-processing Cisco Unified
Communications Manager server within the cluster.
Best regards
David
Jaime Valencia Wed, 03/04/2009 - 11:14
  • Cisco Employee,
  • Hall of Fame,
    2011
i'm not sure, you would need to check with Licensing team but sometime ago this same question popped and the answer is that even if you don't run CCM you need to get it licensed, so a node license per server.
licensing or pre-sales team can get you the definitive answer
java
if this helps, please rate
Correct Answer
Rob Huffman Wed, 03/04/2009 - 15:47
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi ,
Hope this helps!
Rob
Jaime Valencia Wed, 03/04/2009 - 15:55
  • Cisco Employee,
  • Hall of Fame,
    2011
that's the post i remembered! but i could not find it when i looked for it during the morning, good thing you seem to keep all the posts Rob =)
java
Rob Huffman Wed, 03/04/2009 - 16:08
  • Hall of Fame,
    Founding Member
Hey Java,
The ones where we are way "off-base" stick to us like glue ;-)
Cheers buddy!
Rob
APatotski Wed, 03/04/2009 - 23:47
Thank You for help.
Best Regards,
Aliaksandr.
