PA and NM
andy_goes
What kind of PA can we use on 7200 to replace the NM-2FE-2W on 3600?
Are there a table that compare PA and NM?
Thank you.
Edison Ortiz
There isn't a table comparing PA and NM but you can go to the 7200 Series page and view the supported modules under that chassis:
http://www.cisco.com/en/US/products/hw/routers/ps341/products_relevant_interfaces_and_modules.html
In your case, you need PA-2FE-FX
HTH,
__
Edison.
adamclarkuk_2
Level 4
Level 4
Hi, here is a link for all PA's supported
hxxp://www.cisco.com/en/US/products/hw/modules/ps2033/prod_module_series_home.html
