LMS 2.6 / RME db size increasing.
Answered Question
Mar 4th, 2009
LMS 2.6 / RME 4.0.6.
The rmeng.db file increased and I don't know why ?
I've around 2500 devices configured and not to many changes.
At the beginning the db file was :
jan 07 450MB
fev 10 1.2GB
and now
mar 04 1.7GB
Is it normal, that the rmeng.db increase like this.
By the past, I was forced by the TAC to reinit the db after the file reach a 4.5Gb file size.
Any ideas ?
Thanks.
Patrick Vignaud.
Correct Answer by Joe Clarke about 8 years 3 months ago
You should disable those settings which you don't care about. For me, I typically don't care Flash File:* (I check everything under Flash File), Flash Partition:Free, Memory Pool:Free, Memory Pool:Largest Free Block, Memory Pool:Used, Memory Pool:Lowest Free Block, Processor:NVRAM Used.
Overall Rating: 4.3 (3 ratings)
Joe Clarke Wed, 03/04/2009 - 19:09
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
It depends on your configuration. The RME database can grow when there are a lot of Change Audit records (among other things). Some ways you can minimize the number of Change Audit records are to configure inventory change filters under RME > Admin > Inventory > Inventory Change Filter. Check the items for which you do NOT want change records to be generated.
Additionally, if you enable the Config Change Filter under RME > Admin > Change Audit > Config Change Filter, Change Audit records will not be created for vlan.dat archival. This can also save space.
That said, once the RME database grows, it does not shrink. Even purging old records will not cause the database to shrink. There is a procedure to rebuild the database which can reclaim space, but before you do that, you must go through and purge old configs and Change Audit records. The procedure to rebuild the database can be obtained from TAC. A database this large may take the rebuild some time, and LMS will be down.
pvignaud Tue, 03/10/2009 - 21:13
Well,
I don't think that's related to Change Audit Records.
For the Inventory Change Filter, I only have the default (only sysUptime).
I've checked the change audit (vlan). We'll see if it change something.
I do not do "config mgmt" on this LMS.
For all these reasons, it seems to me, very strange to be growing like this.
And for the rebuilt procedure, I've done this by the past, on the same server.
Do the sybase has a db size limitation for v9 and v10 (LMS 2.6 and 3.x).
Thanks.
Patrick.
Joe Clarke Tue, 03/10/2009 - 21:36
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
The fewer items you have checked in the Inventory Change filter, the MORE records will be generated, therefore the MORE the database will grow. You should check everything that you are NOT interested in being notified if it is changed.
You are not archiving any configurations on this server? That is, you are not entering any SNMP read-write or telnet/SSH credentials in DCR? If you are, then RME will try an automatically archive the configurations when the devices are added.
There are no pre-set database size limitations.
pvignaud Tue, 03/10/2009 - 21:42
I was thinking, that the check is for change and not the negative way. In my case, I only have the sysuptime check. What means, all other fields are valid criterias for inventory polling but not the sysuptime ?
No configurations on this LMS.
Only read-only by bulk import csv.
Joe Clarke Tue, 03/10/2009 - 21:50
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Yes, any change in the other fields will generate a Change Audit record.
pvignaud Wed, 03/11/2009 - 20:38
Do you've recommandation on Inventory Change Filter, group and different fields to consider for a regular/normal operation.
Or do I've to trust the default settings ?
Thanks.
Correct Answer
Joe Clarke Wed, 03/11/2009 - 21:59
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
