Packet loss between two routers over a WAN
Mar 4th, 2009
Hi All,
There's a software that its not working appropiately because there's supposedly packets being dropped over the WAN. I have two 2811s connecting the WAN over Fiber. My question is: What is the best software to use or the best way to see the packets being transferred or dropped over the WAN? Besides looking at the ''show interfaces'' on both routers...
Thank you!
paolo bevilacqua Wed, 03/04/2009 - 11:12
  • Hall of Fame,
    Founding Member
Any software should produce the same results, but you should verify against "show interface".
fedecotof Wed, 03/04/2009 - 11:44
Can I use Netflow to get better results?
Or what is the recommendation?
Thanks.
paolo bevilacqua Wed, 03/04/2009 - 12:36
  • Hall of Fame,
    Founding Member
Netflow is more to know what is going where rather than basic counters.
For simple monitoring I would recommend PRTG, Solarwinds,SNMPc, there must be many others.
