Excel template for auto switch configuration?
Mar 4th, 2009
Does anyone know if there is an excel template that has basic router or switch configuration commands where all you do is type in the value or option then it exports into text or csv? I'm not interested in gui interfaces.
see attached..
It probably does not exist b/c of changes IOS version as well as differences b/t models but I'm just curious.
Bernie
Overall Rating: 3.5 (2 ratings)
Leo Laohoo Wed, 03/04/2009 - 13:37
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Have you tried using Smartports Macros?
Configuring Smartports Macros
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_44_se/configuration/guide/swmacro.html
This is dependent on the model of your switch. This is applicable to the low-end switch up to the high-end ones.
To verify, just type in the command "show parser macro brief".
Hope this helps you.
Leo Laohoo Wed, 03/04/2009 - 13:48
  • Hall of Fame,
    2017 LAN, Wireless
I've created a small macro for you to use.
macro name MyMacro
hostname $host
clock timezone PST -8
username admin password 7 $password
ip domain-name $dom-name
# Keywords: $host
# Keywords: $password
# Keywords: $dom-name
If you need to invoke this macro, do the following:
conf t
#macro global apply MyMacro $host MYSWITCH $password Cisco $dom-name acme.cayote.com
Does this help?
Leo Laohoo Fri, 03/06/2009 - 16:25
  • Hall of Fame,
    2017 LAN, Wireless
Please rate if this is successful. Thanks.
